Why is my template transparent?
Solved Lukas Wohlrab ● 10 years ago
I am working on an iPhone 6 app and the template which is a side menu is transparent for no reason (at least for me).
The side menu contains a rectangle aswell as some buttons. The rectangle color is white, but as soon as i apply the template on a screen, it becomes transparent. The same happens when I put a background color on my buttons.
It must be something about the default settings of the side-menu, but how do i change these?
Thanks in advance,
Lukas
Hi Lukas,
This occurs in order to distinguish between the template and the screen elements.
You can deactivate this option at : View / Fade Template Components.
The problem also occurs when i simulate the screen. The background of the side-menu is not visible. Everything underneath the menu is still as visible as without the menu above.
However I found an other way to solve my problem, so this case is solved.
Anyways thank you for your reply,
Lukas
