Updating content
Solved Damoclesosiris ● 7 years ago
Hello, I would like to know how to update the data of a data master without having to install the app againIs it possible to create an event that loads the data from the data master when the page loads?For exampleI have a main page with news, and I want to be able to modify the image of the news and to modify it in the app without having to install it again, simply loading it againSupposedly when modifying the data master it should be modified in the app as well, but it does not happena greeting
Replies (5)
How are you trying to update your Data Master? You should be able to update the information in your Data Master in the 'View and Edit Records' tab'.
Yes, I can update the data from data master, but the data does not change in the app if it is not installed againIs there any way to make them update when you open the app?
What do you mean by 'installed'? Do you have a screen recording of what is happening? We are not sure what you are referring to.
I will explain it from the beginning
I create a news banner on the main screen, with a data grid
I create a data master with news photos
I export the project to the native app, install it and see the banner news without problems
Now I want to update those news by modifying the data master from justinmind prototyper and update them in the app I have installed without needing to reinstall it
a greeting
You will need to export it through Native App again, or learn how to alter the code of the application on your phone so it will accept the new data.
