How do you sort Filtered Results in a Data List... aka sorting data after it has been filtered?
Answered Kevin ● 9 years ago
Hi --
I am trying to figure out how to sort data in a Data List after it has been filtered (but also sort the data even when the filter is not active). I have used https://www.justinmind.com/support/how-to-simulate-a-real-time-predictive-search-in-your-interactive-prototypes/ and I want the results to be filtered but every time I perform the sort, it goes back to the full list? However, I do not always want to sort after filtering.
Any suggestions?
This question is vice versa too... apparently my Filter function just stops working if I choose to sort a column first.... very frustrating :(
Hi Kevin,
The following example should help.
Hi Sonia, thank you for the assistance. Is there any way you can send it not via a .rar file? I can't open it with this device. If not, no worries. Thank you.
Hi Sonia, the example doesn't have a filter nor a sort event in it. Do you have any other examples? I used the Filter example in the link I provided but every time I sort something after, it wipes all the events related to it.
Also, I found a way to open the .rar file so you can send it that way.
Thank you!!
Hi Kevin,
Here you are a new example. I hope it helps.
