Exporting my Justinmind file to HtmL opens an Html of a previous version
Solved Victor Conesa 12 years ago
I worked on a Justinmind prototyper file a few months ago and am now working on it again. After changing several things, and saving these changes in this document and exporting it to Html, an Html site is opened that does not contain any changes that I made. It shows the document in the way it was a few months ago. I don't know what to do, any help on this matter would be greatly appreciated as I'd need to send something off tomorrow.
If you have this problem, please attach the .vp file and the exported html folder here for us to test. Make sure to compress both to .zip format before attaching them.
Replies (9)
Hi Naina,
are you using a different version of Justinmind Prototyper?
I would like to run a quick test. Create a new prototype, insert two or three shapes, images, etc, create another screen and link each other. Then, export to html and test it.
Hi Albert,
Thank you very much for your quick reply.
I think there was an update in Justinmind to a newer version when I was working on the 'old' document, before I started editing it. The version I am currently working on is 5.5.
I created a new prototype with shapes in two screens that I linked to each other and I exported it to html. The html site works fine.
Does this mean that I should copy and paste all the screens of my document into a completely new prototype to make the export to html work?
Thanks and kind regards,
Naina
Hi Naina,
Create a new prototype, select the device (pc, iphone, ipad..) and choose the option "Another prototype file". Search your project, save it and then export to html.
Hi Albert,
Thanks, but following this procedure leads to the same result - the old version without the changes that I performed in the past days opens up and is exported to html.
Is the only solution now to copy and paste every single screen into a completely new prototype or would this also have the same result?
Hi Naina,
could you send your old prototype and the new one? Please, tell me one or two change that you have made.
Hi Albert,
I will complete the document first before I send it to you.
Naina
Dear Albert,
you can successfully close this ticket now :).
For some reason, it works again today. Maybe it's because I fundamentally restructured several screens in there whereas yesterday I was working on concepts in single screens.
Thank you for your help.
All the best,
Naina
Hi Naina,
Great that it works now :)
If anytime you need help, please write us.
Best regards
