Upvote 3
ERROR: "Unexpected error. The operation could not be completed." I cannot Commit anything to my shared prototype!
Solved Victor Conesa ● 13 years ago
Whenever I try to commit anything from my prototype, I get this error. It tells me nothing. What can I do? How can I proceed? I am a paid customer and need to use this immediately!
Replies (7)
I'm afraid we'll need to check our server. Meanwhile you can save your prototype and share it again as if it were another prototype
I am trying to commit a shared prototype but get popup for "Unexpected error. The operation could not be completed."
Log shows following. Please help.
[main ] [2013-05-09 03:40:54] INFO com.justinmind.prototyper - Teamwork commit
[main ] [2013-05-09 03:40:54] INFO com.justinmind.prototyper - Save: /Users/jsmith/Justinmind/5.1.0/teamwork/d59d511b-3556-4f8b-b4a3-468696e22989/current/
[main ] [2013-05-09 03:40:55] INFO com.justinmind.prototyper - Exportig unzipped...
[main ] [2013-05-09 03:40:55] INFO com.justinmind.prototyper - Saved successfully!
[main ] [2013-05-09 03:40:55] INFO com.justinmind.prototyper - Teamwork update
[ModalContext ] [2013-05-09 03:41:03] ERROR com.justinmind.util.JAXB.AbstractJAXBHelper - Error unmarshalling:
javax.xml.bind.UnmarshalException
- with linked exception:
[org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.createUnmarshalException(AbstractUnmarshallerImpl.java:335)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.createUnmarshalException(UnmarshallerImpl.java:512)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:209)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:175)
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:157)
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:204)
at com.justinmind.util.JAXB.AbstractJAXBHelper.unmarshal(AbstractJAXBHelper.java:73)
at com.justinmind.usernote.d.b(d.java)
at com.justinmind.teamwork.bb.a(bb.java)
at com.justinmind.evc.operations.teamwork.TeamworkCommitOperation.doOperation(TeamworkCommitOperation.java)
at com.justinmind.usernote.shared.v.a(v.java)
at com.justinmind.teamwork.lb.a(lb.java)
at com.justinmind.usernote.b.run(b.java)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:441)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1388)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1018)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:116)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:203)
... 12 more
Hi Robert,
Please can you zip the contents of the next folder and send it to us?
Best regards.
This should be fixed in version 5.5
I've got version 7.2.0 and I still or again have this error.
I have a JustinMind account. I can log in from within JustinMind (v 7.2.0) to manage prototypes. But when I try to share a prototype, I get an error; "Unexpected error. Operation could not be completed". Do I need to set up some account information within JustinMind?
Hi Driep,
We have already fixed the issue related with publishing prototypes so you should be able to publish your prototypes through Usernote.
