Upvote 4
Cropping
Answered Victor Conesa ● 14 years ago
Hi, I have pasted an image (image1) into justInMind...I am tring to get rid of the white space around the image1 so that it can overlay on top of another image (image2). When I am active on Image1 and click the cropping tool from the menu, not happens.
Could you help?
P.S. - I just downloaded your product and will be purchasing....great stuff!
To crop an image, right click on it on the Canvas, hover over the 'Image' option, which will show a 'Crop' option.
f7245497e12708c623da72124c505c03
Try to reselect the image (select first another object in the canvas and then select the image again). Once the image is selected resize handlers should appear in its corners and sides. Then click on the 'Crop image' tool from the menu. Resize handlers around the image will turn into 'crop' handlers (bold lines). Drag these handlers to crop your image as desired. Once you've finished, click the 'crop' tool again or select another object in the canvas to apply the changes.
