Bugs in HTML-offline -viewer
Solved sz ● 10 years ago
Since version 7.2.2 two bugs appear while running prototypes in any HTML-offline -viewer
1. Simultaneous actions run one after an nother
2. every single tap actions are executed twice. Really annoying bug! Please fix
I ́ve tested with 3 different viewer (e.g. Protosee). On PC /Browser everything runs fine. Also the old prototypes are running fine in all viewer.
Replies (5)
Can you try reinstalling the application to see if this fixes the issue? You can reinstall here: justinmind.com/download
Make sure to unregister your key first by going to Help -> Unregister key.
I reinstalled but same bug occoured.
This happens only with prototypes original build in an older version.
The only way to heal is to open EVERY tap-action-detail and press ok in event window. Annoying job.
Are you aware that there are several more bugs existing which perform double actions? In Prototyper itself every click on "export to HTML" opens two equal windows. As well if you copy & paste actions they appear twice (but this not allways). This bugs where already existing in Version 5
Hi sz,
Can you specify with which old version were the prototypes built ?
The official way of doing this would be using our Justinmind app. You will be able to simulate your protoypes offline once downloaded. Have you tried using it?
I ́m not sure but I think version 5.7.
The official way is no option for big companies. If I see it right it is only possible over the cloud. On one hand it is not allowed on the other it doesn`t work (proxy issues).
Would be great if you add an option in your app to add prototypes via itunes like the 3rdparties does. I guess it couldn ́t be that complicated.
Hi Sz,
We'll take into account.
