How can I change an iPhone 6 size prototype to an iPhone 6 plus size one?
James Dowd shared this question 3 years ago
I created a prototype for an iPhone 6. I would like to change it to fit an iPhone 6 Plus screen. Is there a way to convert it or do I have to start over with an iPhone 6 Plus template? Any help would be greatly appreciated!
Hi James,
Unfortunately there isn't any way to convert directly the prototype. However you could readapt the iPhone 6 prototype by using the option of importing the file and then resize the content manually.
Just select File / Create new prototype / Select device iPhone 6+ / Start your prototype from another / Select your iPhone 6 vp file.
Then you should start readapting manually the contents to fit the iPhone6+ screen.
35ba4887904327836f85bb39384a0ed9
