If 'prototype can't be uploaded to a hosting server as a real working website is disappointing!
In Progress Gary_wynder ● 6 years ago
You can, actually. You can select the option File - Export to HTML and then upload the exported HTML to your server
Hi Danielle,
Does that mean, Justinmind could actually be able to convert your prototype into all the necessary html code for you (under that option) so that you could then upload it to your domain on your hosting server as a fully working website? (With all the same functionality as your completed prototype simulation)? Or is there a lot more involved to it than that? In my case it would entail uploading the (exported as html) prototype to a fairly 'blank' new WordPress installation (With Elementor Pro already installed as a backend plugin - that works as a front end pagebuilder - within that WordPress installation) onto my 'live' domain. And, could it be uploaded as a working website by FTP?
Yes. Keep in mind that it's just a prototype, so there's no database or anything like that being used. The simulation is just that same export to HTML option by the way.
