Created Prototype using an older version .vp. Currently using version 8.6.0
In Progress Bongani Kamanga-Thusi ● 7 years ago
THE ISSUE I HAVE NOW IS: I APPARENTLY WILL NOT BE ABLE TO SAVE DUE TO THE VERION ISSUE. SO WHAT SOLUTION CAN I WORK WITH
You will be able to save prototypes in a newer version of Justinmind that were made with an older version. You will just not be able to open those prototypes again in that older version though (to prevent compatibility issues).
My other challenge is, i cannot locate my f file. Please assist
Can you explain more about the problem? I am not sure how to assist you.
