Dynamic Dynamic Panels
In Progress Kim Wong ● 7 years ago
I want to be able to put the name of a dynamic panel in a Dynamic Master table. So I select the name of the panel from the Dynamic Master table and set the active panel using that name, is this possible?
Do you have an example file that you can attach? We're not sure if it's possible to do what you're looking for without more information. You can attach the file here compressed to .zip/.rar format.
0dd3174a63e8a6824f252e6eca438c00
If you see in the picture I have several events (only three are showing) in which the value of three variables (Selected Question, Selected Stage and Selected Answer) detrermines which panel will be made active. I have serveral panels and so these events are done several times. I want to know if it's possible to put the name of the panel to a variable and set the panel using that variable
