Update a Variable on Page Load before Master Loads
Answered Withers Davis ● 10 years ago
Is there any way to update the value of a variable on page load before a master loads/renders?
So if I have some text on a screen, can I use the text value to update a variable before the master loads. Please note that my question is specifically about masters and NOT data masters.
I am basically trying to create a dynamically generated breadcrumb that looks something like:
Home / SCREEN 1 / SCREEN 2
What I would like to do is have a variable called screen_id that contains the active screen id, which is a number that relates to a data master called screens.
In the screens data master there is a recursive field called parent_id, which I can use to figure out the screen hierarchy in the breadcrumb.
My plan is to add a hidden element (screen_id) to each screen so that when the screen loads the breadcrumb loads automatically.
A workaround would be to add a set value event to every single link in my application to set the value from the source page before linking. This will be really annoying since I have many links throughout my app.
Hi Withers,
We've created an example for you. I hope it helps.
https://www.dropbox.com/s/qjakbjcknja...
