AutoFit text doesn't work (sometimes)
Known Lukáš Úradníček ● 8 years ago
It happened to me multiple times, that "AutoFit text" breaks label into two lines.
Dear Lukas,
Which Justinmind version are you using? If possible, please send me some screenshots.
Hello Sonia,
I was waiting till it happens again. Althought the described situation is a bit different from what I encountered, still it should not happen (I think).
I have an object, broken from master:
e9cd28dd2143129510e20939c3ad86f3
The text in group is set as AutoFit. On edit, the text field does not enlarge, I have to tick and untick the Autofit option.
f27b98a5d702ee836e51e10b2ee681b0
After I tick and untick the AutoFit, it changes correcty. Second very annoying behaviour is when zooming in:
c39a199b2a5c773022cb6685f037d6ea
c6d8c361fbc0a0c96e17180b84243930
It'a the same project, the same dialog, just different zoom levels.
I am using version 8.3.1., which should be the latest version. Also I am a paying customer, I just post here so other people can find it via Google.
Dear Lukas,
For further investigation, I would need a simple example so I can test it and see what might be happening. You can attach here the example in .rar or you can use the Customer Support Portal.
