Wrap Text within a Data List with the data being pulled from a Data Master?
Answered Kevin ● 9 years ago
Hi - I am creating a web-based prototype with a Data List that is pulling data from a Data Master. Unfortunately, the Data list has a good amount of columns so certain text within the table is being cut off and I do not have enough room to widen the column.
Is there a way to wrap the text being pulled from the Data Master?
Please help! I can't figure it out... Thank you!
I only need it to wrap on two lines... not like a huge paragraph or anything... Please help, need this for my occupation. Thanks!
Hi Kevin,
I have assisted you in our customer support portal.
Hi Danielle --
I received your email and I greatly appreciate the help! It worked. Thank you so much for the help.
On a side note, besides email how do I reach my Customer Support Portal? I am assuming it is separate from the 'My Topic' section?
Thanks again,
Kevin
I have same question. How can I see the answer provided for this?
Apologies for the late reply. Just select the text in the Data List and look to the Properties palette. You'll see an option to change the 'Type' to 'textarea'.
