Changing colour of a component using a variable
Answered Robert Brown ● 11 years ago
Is it possible to change the background of a component or rectangle based on a value stored in variable?
Hello Robert,
While you can't use the value to specify the color the component will be changed to, you may use it a condition to determine the next step. For example, if you have a variable with the value 'blue', then you can have a change style event for the component with the following condition:
When variable = blue, change style [background] to the color blue [user selects blue from color picker]
Luisa
