UI Interface text is tiny
Alex shared this problem 4 years ago
I just installed Justinmind on my mac (Retina Macbook Pro, Mid 2012, OSX 10.9.4). When I fire up the application, the text in the user interface is so tiny I can barely read it.
6eca573bf6958ae7129d950773a3bdb7
I literally just installed the package so haven't touched any of the settings. Is there a way I can fix this?
Comments (5)
Hi Alex,
This is probably due to the Java version installed on your machine. Please make sure you have version 1.6 installed and not 1.7 or 1.8.
This will be solved in the next software update; unfortunately for now the workarround is the solution mentioned above.
Marc
Thanks. Unfortunately, I can't change the Java version. I do java dev and we're solely working on 1.7. Thanks anyway.
Completely fixed forever (hopefully) in version 6.1.1
I have this same issue on my Razer Blade (3200 x 1800) but this is a windows machine. :( suuuuper tiny text.
Hi Daniel,
Can you send us an email to jim.support@justinmind.com so we can help you?
Lidia
