Is it possible to scale the application for 3200 x 1800 resolution?
Hassan Ouda shared this question 5 years ago
My 15.6 inch screen laptop has 3200 x 1800 resolution and it is hard to see some of the icons and tools. Is it possible to change the DPI scaling on the application?
If you're using a high resolution display and Justinmind icons appear very small, look for and launch this file and it will fix the issue:
C:\Program Files (x86)\Justinmind\Justinmind Prototyper[version]\JustinmindPrototyperHiDPI.exe
Comments (16)
Hi Hassan,
1. Set your screen resolution to a lower setting. Currently 1920x1080 seems to be the most ‘normal’.
AND
2. From the screen resolution page, there is a setting for ‘Make text and other items larger or smaller’
a. Set the slider all the way to the left towards ‘Smaller’
b. Click Apply (this requires the user to log out and log back in)
Best regards.
I tried, and it still doesn't work. The menu headers are still at 3 point type.
Hello Curt,
I have answered this inquiry through our customer support portal. However, for all other users searching for this topic, I shall post the response given:
The small components are associated with high resolution displays. However, I am happy to inform you a fix for this problem is due to be released in our next update, sometime this month. We are sorry for the inconvenience this may have caused, and will notify you when an version update is available.
Regards,
Luisa
Still awaiting the fix.When is it scheduled for release?
Same here, any news on this?
The editor is actually unusable now on high DPI screens.
i am also awaiting the fix for this problem. all computers now have a higher resolution. please fix this asap.
Coud you please provide an update on this? We are evaluating the software, but it is not usable on our 13" XPS machines (3200x1800)
Any update on this? Just downloaded this program and can't use it because of this issue.
why not just make the high res version available on your site?
Hi Roh,
Currently, there isn't any specific installer. The current Justinmind installer has two versions and there should be two shortcuts, one to the HighDpi version and one to the other.
Look for and launch this file:
C:Program Files (x86)JustinmindJustinmind Prototyper 7.3.0JustinmindPrototyperHiDPI.exe
I use version 8.7.0 and there is no JustinmindPrototyperHiDPI.exe file at all. All system compatibility settings applied to JustinmindPrototyper.exe do not really help to solve the problem.
It's very annoying to use the app on hi-res screen like this...
Newer version of Justinmind should load the high res installer by default. Can you attach a screenshot of how the interface looks on your screen?
Sure, here you are. The UI in general looks and works well. But fonts and some icons on menus and panels are not crisp and clear.
Files: jimp.jpg
It looks like the correct interface is loaded. Unfortunately it might be a little blurry due to the scaling.
Ok. When I set file params as shown on this screenshot, all fonts and icons become nice and clean but the overall drawing gets affected. When I move objects over the canvas it gives various funny glitches. Perhaps this is something you could fix further...
Files: jimp.jpg
