multi select list
oscar ward shared this question 1 year ago
is it possible to have a multi select list expand out of the containing field in the way that a select list does?
0ead6a275c86a209c7b88d78d01d1a35
Yes, you can, but you need to use dynamic panels. Check out this prototype to see how to do this: https://www.dropbox.com/s/37az6dcheiw5e8b/Multi_select_dropdown.vp?dl=0
Thanks for the response, but what im really asking is. if a select list can function like a multiselect
In the example image I attached, both items are in a table and the row heights are fixed. but the select list expands out of the row where the multi select scrolls within that row.
I want to be able to have the multi select expand out of that row just like the select list does.
If as in your example the select list is placed in a panel and that panel is placed in a fixed height table it will only scroll within the viewable area and not expand out of the container
In that case, no - but you could try to create what appears to be a select list through dynamic panels. This might be a little complicated, though.
