Wireframes embedded on webpage in an iframe
sascha.klick shared this problem 7 years ago
We have wireframes embedded in our webpage inside an iframe. This has worked well for quite some time until lately where more and more elements are put in link-tags and our page cannot work with those. Did our designer change some settings in the Prototyper? Did you update the software and the HTML code is generated differently?
IE also does not like any of the PoCs when put into an iframe.
It could be both options. HTML generation changes in every version we release since we are always improving it and fixing previous issues. However, if you have noticed more link-tags, it is very likely that your designer has been defining more navigation events in order to link the pages.
We don't really know what is causing your problem so if you could send an example it would be helpful to find the source. Thank you.
