Windows 8 prototype
Jason Hilton shared this question 3 years ago
How can I simulate on a windows 8 tablet full screen? I am building a windows 8 prototype but I can't figure out how to display full screen. Is browser viewing the only option for windows?
Comments (4)
Hi Jason,
If you are using a windows 8 tablet the best option to view the prototype is to run it in the browser in fullscreen mode.
Sorry for the inconvenience.
Marc
Yeah I am doing that. What I ended up doing was exporting without the comments bar and other controls and then I manually removed the device graphics and padding. Super pain in the butt. There should be an option to export without all that extra stuff.
Hi Jason,
If you have an internet connection, you can log in to your justinmind account and access the prototype from there.
It should detect you are in a tablet and not show the device skin when you export it to HTML.
If it is not, please let me know which device you are using.
Marc
Using a Dell Venue 11 1920x1080 running windows 8.1. I think the problem is there is no detector for full screen. I've manually removed the frame but am still hunting down all the padding and margins. Could you direct me to the correct CSS to remove all this?
I also tried exporting as a web preset which removes all the framing but also removes the gestures. You should really consider adding a clean export version, there are too many devices out there to detect them all correctly. Additionally, adding the ability to toggle gestures on/off when creating a prototype would allow this to be solved easily.
