Why do dynamic panels & groups shift in size & position when editing text within?
Angela shared this problem 5 years ago
I get my panels all set up just as I want them, but if I edit text in a label within one of them, the other items shift position and/or size. For some reason the label field doesn't expand with more text, but the rectangle beneath it does.
This is taking up a great deal of time to resize & reposition the components within a panel or group.
Can you please send your .vp file to jim.support@justinmind.com?
I have the same issue and recorded the issue. It doesn't happen when there are only a few groups, but once the prototype gets more complex, if I select an item within a group and try to move the item using arrow keys. The whole group will shift.
