whether the html output generated via justinmind tool can be used for development also?
Aravind Mohan shared this question 4 years ago
I am also curious about this if the question is about HTML development. And if so, if there are some "best practices" that should be used to make the HTML work better and across platforms.
The HTML code that is exported is not thought for development purposes. You can use it if you like but again, it is designed for simulation purposes, not for production.
Marc
