When two or more components with different dimensions are selected, Properties panel shows "1"
1) Create several components with the same width, but different heights (for example)
2) Select the components.
3) See the following in the Properties panel:
56fd2b7639fca21262acfc33cdd867d8
None of the components has a height of 1, but if the matching dimension (in this case, width) is edited, all of the components will have their height set to 1.
Instead, why not do something like this:
Leave the non-matching dimension out of it.
I have noticed that if you select to components where neither dimension matches, both show "1."
You are right...I'm reporting this bug and we'll fix it as soon as possible.
Fixed in version 6.1.1
