what i iput can not be recorded in datamaster(JIM 5.1)
Jokor hanson shared this question 5 years ago
I am a new justinminder.I got a problem when using JIM5.1 datamaster to record the data. First,i Creat a new datamaster named "contact" with two fields "name","age". Second,I drag a button to canvas and set the interaction ,i choose "DataMaster Action" and new one. The expression was "name=input_1,age=input_2". Then simulate. The result is that what i input can not be appeared in "view and edit records".pls help me
The data introduced while you are simulating a prototype is not persistent. If you want some testing data you have to create it inside the data master.
Well,thank you.
When I drag data master and Data Grid to a same screen(screen1),the data which I input can not be added in datagrid after simuating.
But when I drag the Data Grid to screen 2,the data which I input can be added in datagrid.
The two expression of interaction are same (in Case II, i added an action as"link to screen 2")
Could you plese tell me the reason why there would be these two different cases.
Take a look at this tutorial:
