Weird Roboto Font in Justinmind
Loic Engelhard shared this problem 2 years ago
In Progress
It seems that you are not picking the right Roboto Font in Justinmind based on how certain characters are rendered (see attached document).
How can I select the 'official' Roboto from Google?
Thank you.
Loic
Files: test.png
Comments (7)
Hi Loic,
Thank you for taking the time to report this. Our development team has been informed about this issue and will take into account for future updates.
Any progress on this? We need to use Roboto in our prototypes and your version doesn't look right.
Dear Matt,
I'm happy to inform you that this issue will be solved on our next update.
So an update just came out and the Roboto rendering issue has not been fixed.
Please look at the attached image. You can see how Illustrator renders each heavier face in the family in a nice even fashion as you would expect. However, in JustinMind the Medium face renders as heavier than bold or black... the all-important hierarchy is rendered useless. Roboto is the primary font that our platform uses and "medium" is the primary thicker font face we use... except i have to use bold instead... and Medium is not useful at all. And using Bold in place of Medium means I cannot use Bold at all.
This is something that needs to be fixed.
Agreed. The characters look correct, but the weights are off.
Hi all,
For further investigation from our engineers we will need the following information:
1. Which OS are you using? And version?
2.Are you using any font manager?
3. If possible, can you try installing the Roboto font directly from Google and let me know how this works for you?
Thank you in advance.
Hi all,
We have launched a new version (8.0.1) to solve the fonts issue. To get the new update go to "Help" / "Check for updates".
