Version 6.1 changes font size
Alex shared this problem 4 years ago
Version 6.1 changes font size in text cells on a text table.
Size is decreased one level of the sizes list every time I edit the text of a cell.
Comments (5)
Are you using a Mac computer with Retina display?
No, I have a Windows 7 laptop with 1920x1080 resolution.
I also see different font sizes in editor than the actual prototype, which makes very hard to use prototyper since last upgrade. The worst is that I cannot go back to a previous version, as some prototypes I created are only compatible with this version now.
Thanks for your time.
I have this same problem and DO have a Mac with Retina.
When I set the font size to say 16 in Justinmind it appears MUCH bigger in the program, but once exported the actual font size matches the number specified in Justinmind. If I reduce the font size so it LOOKS good in Justinmind (say size 10) it then comes through looking much smaller in the exported prototype.
This makes the program VERY hard to use. It's almost quicker just to prototype using HTML because the process is about the same.
Completely fixed forever (hopefully) in version 6.1.1
