Using the tree view and obtaining the selected node value.
Matt Klassen shared this idea 7 years ago
Completed
Is it possible to get the value of the selected node from a tree view and use it to set the value of a label object?
I have a tree view, and would like to use the selected node to select data. Can I extract the selected node and save it to a variable?
I'm sorry but you can't use the node as a value in a variable. It's a good suggestion though so we write it down.
Sad that this feature seems to be not yet implemented.
Also tree component should have an event for selected node change.
