Using on Key Down (Enter key) to filter the grid?
Rebecca shared this question 5 years ago
I'm trying to create an interaction for the Enter key on a grid filter (search). I've seen the video http://www.justinmind.com/support/how-to-simulate-searches-in-a-data-list-in-your-web-prototypes-single-criteria/ Clicking the search "button" works right. However, I also want the search to run after hitting the Enter key (like a normal search). I did everything the same as the button (set value > calculated > filter conditions [grid, search textbox]), except I used the "on Key Down" event. Yet, when I type in my search terms into the textbox and hit Enter, I get [object object] in the search box. What am I doing wrong?
Comments (4)
Could you verify that the target of your set value action is the data grid? It looks like the event is changing the value of the search box instead.
Oops, I did have the search box as the changing value - so I updated the condition to set the value of the grid and it worked great. Thanks for the fast response!
One more question - I have a datacount on the grid records returned and I want to display "No matching records" if no rows are returned. I tried an "on change" event to "show" a label if the datacount = 0, but the label still isn't showing. Any suggestions?
I think I need a bit more of information. What element has the 'on change' event defined?
I figured it out - I had the label inside a row of the grid, so when the grid didn't have any results, it hid my label as well.
In case anyone else wants to have a "No matching results" label appear if the grid is empty, I created an 'on Change' event on the search box, set the action to "Show" the label, and added a condition "when [count(mygrid) = 0]".
