Usernote not working the same as simulation
Athelene Gosnell shared this problem 6 years ago
When I publish to Usernote, the links on tabs are not working. However, they work fine in simulation. Any suggestions?
Could you tell us what web browser are you using please? You can send your .vp file to jim.support at justinmind.com if you like so we can take a look at it.
Victor & Athelene,
Both of the two following work in simulation as expected but not in Usernote.
1. When moving the cursor between rows of a data master populated data grid, the on leave function only works when you leave the entire grid, not just the row.
2. On click does not carry out its instructions when couched within a data grid row.
my usernote project is BD eXchange Vs 7.03.1
Seems you will have to make a little change in your prototype in order to work.
Can you send an email to jim dot support at justinmind dot com with the vp file so we can explain to you what is the problem and help you to correct it?
