Update Widgets
CrisfinMichael shared this problem 7 years ago
is there a way to link a widget so it can be updated when i make changes to the actual file it self.
Comments (5)
I'm really sorry but I don't know what you mean by 'make changes to the actual file'. Could you explain it a bit further please?
have you ever use any adobe products like photoshop or indesign, if you have then thats what i mean saving a file on a different application and adding it to justinmind. lets say i design a image in photoshop i took it in justinmind am i able to update the file on photoshop and once i save it will it update in justinmind. this is what i ment by making changes to the actual file.
Any time you insert an image into a prototype the image file is copied so the .vp file contains all the info in the prototype. There are no links to external content.
so is there any way for me to update the files with out me having to take time and add widgets one by one
You can use masters to those widgets that have to be changed in all your prototype every time you change one of them. Take a look at this video to know more about masters http://www.justinmind.com/tutorials/m...
