Unknown Error when uploading
yb shared this problem 8 years ago
I receive an "Unknown Error" message when I try to upload (replace) a new prototype.
For what it's worth - the problem seems to be sporadic and when using chrome the filepath is listed as c:fakepathxxxyyy.vp - even though it is in a different directory / I'm on a MAC (so no C drive).
Look forward to your feedback,
Y
Comments (5)
Sorry for the inconvenience. I should be fixed now.
About the c:fakepath.... it is normal, chrome replaces the real path of your file by "c:fakepath" so javascript can't know or access it directly. It should work. It is ugly though, so we will remove that fakepath text in a future release.
Best regards,
Enrique Cano
Hello all.
I'm having the same problem now, it's very hard to upload the file to the server to test.
I tried to upload from Chrome and IE but I got the same error.
Could you help me to solve it?
ac6ff15ff3c1452f3e823afd4b2de8cd
Hi Alexandre,
We've contacted you through our customer support panel. We'll have a solution for you very soon.
Hi, Danielle, I see that these posts are a bit old, but I need questioner something to you, I'm trying to upload a file, in the prototype, adding data to the "data master" but when I visualize the "data grid "it appears only text fields, but not the image ... appears something like" fakepad" You know how to fix this?!
Hi Rodolfo, We've contacted you through our customer support panel. We'll have a solution for you very soon.
