Unhide a widget when a variable value is greater than 1?
RS shared this question 6 years ago
I'm using a series of check boxes and radio buttons (on seperate panels) to increment a variable value by +1 each time one is selected (I'm hoping it automatically decrements by -1 when unselected). In a seperate panel below I have an indicator widget I need to show when the value of the variable is greater than 1. a35eaa17544fd27a4e10cbffc395ecfd
First of all I have to tell you that you'll need to decrement the variable when a checkbox is unselected, it isn't decrement automatically as you expected.
Concerning your question, you'll need to write a condition to evaluate if the variable value is greater than 1, then add a "Show" action to display the indicator widget if the condition succeeded. Here you have more information about conditions.
