Unable to scroll image despite setting the scrollbars of dynamic panel as visible
Anu Varma shared this problem 5 years ago
Hi
I am working on a prototype for iPhone5 and I added a image to the dynamic panel after setting the vertical and horizontal scrollbars as always visible, but when I simulate the prototype, I can not scroll the image which is larger than the dynamic panel.
I have also set the "pinch close" and "pinch open" events for the image which work fine, but I am unable to drag the image on simulation. Before simulation, it is scrollable. Could you please suggest a solution for this?
Can you please send your .vp file to jim.support@justinmind.com? I will take a look at your prototype.
