Unable to move, edit, or delete imported widgets from a version 5.6 prototype file to a 6.0 prototype file.
Ron Schlegel shared this problem 4 years ago
After importing my own widgets I cannot move, edit, or delete them as I could in v.5.6.
In version 6.0, you can manage the widget libraries using the menu option 'Widgets -> Add/Remove widgets'
This feature enables me to add/remove, edit name, share and export entire libraries, but not individual widgets. How do I delete, move, and edit the name of individual widgets?
First add it from that view to the palette. Then close that dialog and, in the palette, click on the 'gear' icon next to the name of the library. There you'll find an 'Edit option'. Select that option and the library will be on 'edit mode'.
