Trigger either a URL or an HTML POST/GET from an event?
NickN shared this question 5 years ago
Is it possible to trigger an HTML POST or GET from a button/event?
In my prototype, I'd like to trigger a REST API from within the prototype. The user would press a button, which would fire off the POST command. The POST simply triggers a server side event (e.g. updating a server side counter). It does not return anything to the prototype app.
If this is not possible, it is possible to trigger loading a URL in a hidden element (i.e. an element that isn't viewable by the user)?
Hi NickN,
You can use images map to trigger any external URL wherever you want. On the following link you will find an example of how to do it.
Now, select your image map zone and add an event action. Select 'On click' and link to. Then, click on External Address and write the URL that you want to use. I add you an image of how to do it.
4bf5a1873b12780f29412029fd061650
I hope it helps you.
But if I enter a URL, won't that open a web view? Since I'm trying to trigger a REST API call, I really don't want the link to open a new window if possible (or at least not one that's visible).
Hi NickN,
You can try to use a hidden URL Widget and show it by events. You will find the URL widget on the widget menu, as you can see on the following image.
8145267e4acad59965bab0b0e938d52b
I hope it helps you
