Tree nodes not properly aligned when lines are hidden.
Anton Tandiono shared this problem 6 years ago
The tree nodes look fine as long as the lines are shown. But once the lines are hidden, the nodes are not properly aligned in the exported HTML.
The second subnode is aligned with the parent subnode.
To reproduce:
- Create a node with 2 subnodes.
- turn off the lines of the tree.
- simulate and open the parent node.
Comments (4)
Correction:
The issue arises when there are 2 third level nodes.
So Instead of
node
node
node
node
I see:
node
node
node
node
10836c3f5d418f0fe101a7fd2ec59929
You're right, it happens in that special case. I'll notify it to the development team.
This problem still persists, but in cases where the node name is outside the defined boundary.
5afc732c9117c2fff7ae3a3881500f49
Thanks for letting us know, I've reproduced the error in our computers and will contact the development team. For now I would suggest tomake the tree component wider so the text fits or make the message shorter (possibly add "..." if the message is too long).
We will let you know when we know in which version this will be solved.
Marc
