The trial version 4.4 will not will not launch
Doney shared this problem 7 years ago
Comments (19)
Could you give us some details about your computer please?
I am using Windows XP
Could you post an image of the contents of this folder please?
c:Program filesJustinmindJustinmind Prototyper 4.4.1plugins
14d2494c2a04119269efa813d4b78abc
10e11e7941d92a7ebcdff46a38c0f28c
bd51a4cc7e7aabb48adf270604d0e053
92e83279fdcb615518c9685f5bcc2fa8
It looks like the installation process finished correctly. Could you post the contents of this file?
c:Documents and settings[your user name]Justinmind4.4.1logs.log
I don't see any log files
Ok, then go to c:Program FilesJustinmindJustinmind 4.4.1.metadata and post the .log file. Check also the folder called configuration and post all the .log files there.
08b0c909fafd9172c0ea92d497302b8e
Ok, I see in the other snapshots that you installed Prototyper in a folder called d:downloads, could you go to d:downloadsJustinmind 4.4.1.metadata and post the .log file. Check also the folder called configuration and post all the .log files there.
I don't have a metadata folder
What about the 'configuration' folder?
The folder is empty
My goodness... Could you tell me more or less the steps you followed to install Prototyper? I mean, it was a different user the one who installed Prototyper and the one you use to run it?
Is there a number I could call?
I was just informed that my company has purchased licences for the product.
We replied to you by email.
