The layers appear unordered
María Pérez de Arrilucea shared this problem 4 years ago
When I make groups with objects, they change the layer order. But they change in the Esquema panel and not on the page. For example, I have a master and I want to make it clicable. I create a transparent object to make the link and I put the master below:
1. link
2. master
This is the order I have. Then for whatever reason, the Esquema panel changes the order of the layers, and this is what I get:
1. master
2. link
Like that it should not work because the link is hidden by the master, but it does. On the page and the html they work ok but it is not correct on the panel.
This situation is really confusing, as I can never trust the panel to know which layer corresponds to which object. And sometimes I get lost.
Can you fix this, please?
a3b45324973a8b07f2c8f67406a01a4c
Comments (6)
Hi María,
I'll add this to the other post you have about the z-index because they might be related.
I'll let the development team decide that but we will let you know in which version this will be solved as soon as we know.
Marc
Thanks a lot Marc!
Hi María,
Could you let me know which Justinmind version you were using when this happened and the versions you have detected this happening?
Thank you!
Hi Marc,
It happened with 6, and I think that with 6.1 too.
Hi María,
This issue should have been solved in version 6.1. Can you confirm that you detected it in version 6.1 so I can notify the development team?
Thank you for your collaboration.
Marc
Hi Marc,
It happened in 6.1 but I haven't been able to replicate it now.
