Testing my first prototype on device.....many issues
Kwek Guo Xiang shared this problem 4 years ago
Hi all, my first time using JustInMind for prototyping. I finished my first prototype and wanna test it on my device. I published it in usernote. I have no idea how to test it on my iphone 5 device. However when i play it with my desktop....every screens are so lag and worse of all is my bowser component which by right showing maps are not showing anything.....
Help Help Help
Comments (6)
Are you using the Pro version? If so, there should be a blue "View on device" button on the top right part of the screen
38c2a4bd8ce18ac566418110064022d0
Hope this helps.
Best
I figure it out already...becuz after I publish I did not set to public. Btw may I know why all screens are so lag? I mean the screens are loaded in a veey slow manner from top down. How can I improve on the smoothness? Secondly is it possible for me to change the app laucher icon to my own designed icon after I added it into my home screen?
Thabks for the reply. Appreciate it.
For the first issue you can try try increasing the memory used by Justinmind Prototyper. In order to do that change, go to your Justinmind installation folder and open the file 'JustinmindPrototyper.ini' with a text editor. Write 1024m next to the parameter -xmx, so it reads -xmx1024m (instead of -xmx512m).
Also, try to reduce the quality of the images.
For the app launcher: click on simulate on the toolbar (not the green button at the top right), Simulation Settings..., and finally select a file next to the app icon label.
Best regards,
Marc
Thanks for the reply...the app launcher issue has been solved thru ur suggestion. as for the lagness...."go to your Justinmind installation folder and open the file 'JustinmindPrototyper.ini' with a text editor. Write 1024m next to the parameter -xmx, so it reads -xmx1024m (instead of -xmx512m)."sry i do not really uds what u meant.
and any possible way to have my proto be stalled locally on the testing device(iphone5)? However i have added a browser in one of the screen...i believe it have some implications right
i have removed all my browser to images....sry but i cant reduce the quality of the images...can teach me how to make it lag free when view on device??? anyway to make lagless? like storing locally on the phone or using some external apps.. thanks...hope u can get back to me asap as abit urgent
Please take a look at this tutorial. I believe the three apps (i would suggest the third one) mentioned are going to help you store the web locally.
Let me know if this makes the screen transition faster.
Best regards,
Marc
