Template overlaps grids
onemhz shared this problem 6 years ago
I'm trying to prototype a report that uses several data grid components. In order to keep the grids from overlapping, I set the layout to vertical, but then it seems to ignore the header in the template and so the header appears over-top of the grid.
The template is set to free-layout, but I tried putting the header components into a dynamic panel and setting the template itself to vertical. I also tried putting the grid in a dynamic panel, but the panel stays a fixed size, so if the grid runs over, it just gets cut off. I don't want to paginate.
How can I do multiple dynamic grids inside a template?
I think this video tutorial can help you a bit with that http://www.justinmind.com/prototyper/...
I figured out what I needed. In each screen, I had to put a transparent rectangle in where the header would appear. It would be nice if the header I have in the template could count in the vertical layout of the screen.
You are right. You can place image map instead of transparent rectangles if you like.
