Tap Hold gesture throwing up "Copy" window in Safari on iPhone5
Branch Hendrix shared this question 5 years ago
Tap Hold gesture when exported to HTML and run on iPhone 5 in docked launch model will throw up a "Copy" Window around the content that is associated with the Tap Hold gesture. Is this a bug? A Safari behavior?
Comments (5)
It shouldn't appear, it's a default safari behavior but we disable it on our prototypes(except if you tap&hold in some specific widgets like inputs). Please could you tell me in which kind of widget did you performed the tap&hold gesture?
its on a row within a datagrid; the row does have input fields
Should I draw an image map over the input fields to eliminate the issue with input fields?
If you put an image map over the input fields you won't be able to input any value on them. Are these inputs editable?
The input fields are linked to datamaster fields and are essentially read-only
There is no problem then, if you want you can add these image maps over the inputs and the issue should be solved.
