Tap and hold pressed states
Daryl shared this question 4 years ago
In my current touch prototype, I have a tap and hold action on an item that also has tap action.
The prototype has an off state, pressed state and on state. Because tap is an immediate action, the pressed state shows right away. Because tap and hold waits to make sure it's tap and hold, the pressed state doesn't show up until after the prototyper file has determined that it is actually a tap and hold. Since this is a function of prototyper and not a series of action events, I can't control the timing.
Do you have a recommended fix or a way to do pressed states on tap and hold actions?
would you mind sending your prototype to run some test to jim.support@justinmind.com? Maybe exists some workaround but I will like to see if it's possible to use in your case.
Regards,
