Table Filtering
lebrigadier shared this question 7 years ago
I have a data-master based table and i want to filter it by different terms.
The prototyper tutorial explain how to simulate searches using a text input and a button, and it works, but not if i use a selection list indeed of the text input.
How can i resolve it?
Comments (5)
The tutorial builds this expression filter(datagrid,input text) to do the search. If you want to have different terms to search then you have to build the expression filter(datagrid, (data master attribute) has (input text)). If you add several interactions like this, one after the other, and always filtering the same data grid, you will be able to filter using different terms. Ask me for a prototype if you find it difficult to understand.
Thanks for the reply, but my problem is not about concatenating filters is just about filtering by the selected item of a selection list. Thank you again.
Then you have to define this expression: filter(datamaster, (data master attribute you want to filter by) has (select list))
Thank you very much. It works perfectly!
This bug will be fixed in the next update
