Summary widget only in English?
Markku shared this question 6 years ago
Data Grid Summary widget is only in English language format. I would like to be able to localize the language myself.
You can try to create your own summary widget using the 'Count' function in the 'collections' tab and storing in a variable which page is being shown in the data grid.
What element shall I use as data source to 'Set Value'?
Shall I drag the whole data grid to the empty square?
The set value must be applied to the label. Then the value would be an expression such as Concat(Count(your data grid)," number of results found")
