software is crashing
Doug shared this problem 7 years ago
the software is crashing every time i try to save - gives me an unexpected error message
Comments (8)
It happens with any prototype or just with one?
with all of my files. My computer had crashed while justinmind was open. When i restarted i had to recover my files. The recovery opens the files but when I try to save the recovered file justinmind crashes.
Try this:
Open the c:documents and settings[your username]Justinmind4.3.1etc there replace the file recentFiles.xml by this one:
http://justinmind.s3.amazonaws.com/re...
That should work
Hi Doug,
Did it work?
This appears to have done the trick. Thanks.
That probably means you saved a file in a path with non-english letters. It should work in most of the cases though.
Has the fix file changed locations? I'm having problems with frequent crashes on attempt to save as well.
There is a problem with the encoding of the file that stores the paths to the recently opened files. We have addressed it already and we will probably launch a micro update with that fixed in it in a week or so.
