Sketch plugin not exporting artboards to Just in Mind
Silvia shared this problem 21 months ago
In Progress
Sketch plugin is not exporting artboards onto Just in mind. It gives me an error message.
I really do not want to have to re-do all the work again.
Any ideas?
Comments (5)
Hi Silvia,
Thanks for reporting this. Can you send this info along with the Sketch file to jim.support@justinmind.com ?
I am also having the same problem when I am trying to export layers from Sketch to JustInMind file. This only happens when I uncheck "Export text layers as images"
https://gyazo.com/8cda2a8e6bb9ef3cf8bb3f5c1a8e19f7
https://gyazo.com/a44ce0f5ac8437664b806ffc51f64890
Hi Rachel,
Thank you so much for that info. Does this happen for all Sketch files when you uncheck "Export text layers as images," or just that one?
The process seemed to be running/exporting fine until it hit that specific art-board/mockup in Sketch. Then it failed.
Hi Rachel,
Try downloading the new version of the plugin here: https://github.com/vconesa/justinmind-sketch
If this issue is still occurring after this, please let me know, and if possible, attach the sketch file.
