Simulate doesn't work on 2nd monitor or projector
Luis Lee shared this problem 7 years ago
It's not possible to simulate my project when using the 2nd monitor or a projector. When using the second monitor the buttons doesn't work.
Wjen projecting and even when I've tried to project by using duplicated screens the options are not working properly (combobox list doesn't show).
Comments (5)
We are already working to fix that but meanwhile you can use the 'Export to HTML' option.
Ok, Thanks for the info, I'll do that.
any resolution to this yet? do you have a best guess on a time frame to push a fix?
It will be fixed in the next update, around May the 22nd
Solved in Prototyper 4.6 release
