Show specific rows in datamaster
maira.khouri shared this question 7 years ago
I want to view only a specific row of datamaster, for example:
One table has columns ID, Name, Description and i just want to see the rows that contains "Name ABC" on column Name.
Is it possible?
Piece of cake! Create an onPageLoad event that triggers a set value action over the data grid. Then as the value build a calculated expression with a filter function with the data master in the first parameter and data master attribute name = Name ABC.
How can I filter a datagrid based on 2 input fields (street and number) and simulate an ajax like behaviour. it works perfectly with the key pressed event on the street field, then the datagrid displays all streets meeting the criteria (first 2-3 characters), but then, when the user sees for example "street 1" and "street 2", I want to the user to be able to put in for example "1" in the number field and the datagrid should display only "street 1". is that possible?
You could refine your condition in the filter to something like this filter(dataMasterAddress, (address.name has input1) and (address.number has input1))
