show a group on tap...hide on untap of a checkbox
Godslove Chinekwe shared this problem 5 years ago
Hi
I need some help please....am working on iphone template...i need to reveal a group of input and button when a chekc box is tapped and hide the grouped input and button when it is untapped......the reason is that the checkbox has to be selected before the user can see the input and button....Note please I have watched this http://www.justinmind.com/prototyper/...
I have also looked at this thread https://www.justinmind.com/community...
and could not figure it out.,...would appreciate it if i could get some help...perhaps
video simulation of the steps would be great so others can use that later...thanks
Add to your canva the checkbox and all the inputs and the button that you want to show or hide. Group the elements that you want to be hided by default.
Now, select the checkbox and click on add event. Go to add condition and built this expression.
1b07e4c1e17c4956998a0e563b20eaa2
Now, click on show / hide action, select the group and choose the action show.
To do the oposite action, just click on "else" and built the same action (show / hide), but this time, you have to select the hide option. Also, you have to include the following condition.
That's all
Hi am doing this on iphone template in justtinmind....
it does not seem to be the same
first of all there is no onclick...I can only see ontap...amybe be becaseu it on an iphone template
2. when i do the first event of on tap ...i do not see the "else" tab to click on...how do i get the else tab...so i can show the second condition...please
1. For iphone is "on tap". It's the default action when you click "add event".
2. When you have finished the first action with the conditional, on your right, under the action, you will be able to see "else". Take a look to the picture
8deedad004658e3976a839c77582575a
