Share an element across multiple pages
arabesq610 shared this question 4 years ago
How can you share an element (such as a navigational menu, for example) across multiple screens/pages? I assume this is possible, but the only thing I've been able to figure out so far is how to copy an element and paste it onto multiple screens. However, when I need to make changes to that element, I don't want to have to update it in multiple places. Seems simple enough, but I can't figure out how to do it! Thanks in advance for any help.
You need to use the template menu. If it does not appear, check under "view." Create a template with the elements you want to have on all page. The when you add a screen/page use the pull down menu to base it on the template you created. Hope this helps.
